display safe
This forum is for English language discussion about Opels, Opel Club Finland and related issues
AdamOPC
display safe
Viesti Kirjoittaja AdamOPC » 25 Loka 2015, 13:35
Good day everyone! i recently got used CID display of Ebay. After installing it to my car i now have "display safe " and "programme display" messages. :bonk:
i have no idea if display was divorced from a donor car but i have all the codes from a car pass for display and head unit. I was wandering if there is any tech2 guru on this forum who could help me get read of error messages?
Re: display safe
Viesti Kirjoittaja kadett90 » 25 Loka 2015, 15:01
Where are you from?
If the display is not divorced there is no way to get it work.
At least easy way.
- Masa -
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 25 Loka 2015, 15:56
i live in Helsinki. i just talked to "Pecky" from VXRonline and Tech2guru. . He said that display is completely reset and ready for programming so i would need some easy programming to get it work. Can you help "kadett90" ? or maybe direct me to someone?
Re: display safe
Viesti Kirjoittaja kadett90 » 25 Loka 2015, 15:58
I have equipment for that but I'm a little bit far away.
There might be opelscanner or op-com users nearby.
- Masa -
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 25 Loka 2015, 18:26
you live in Hämenlinna? Are you sure you can do it? i could come to you some day .
Re: display safe
Viesti Kirjoittaja kadett90 » 25 Loka 2015, 19:02
I can't be sure but I have done that on my Omega B.
What car you have?
Have you got security code for the new cid and the car's security pass.
- Masa -
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 26 Loka 2015, 11:29
Yes i have all the codes. Astra h OPC 2006
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 10 Touko 2016, 18:17
Still looking for anyone around Helsinki with Tech2. Please let me know if you have it or know anyone who can help. Please please :)
Re: display safe
Viesti Kirjoittaja kadett90 » 10 Touko 2016, 19:42
Before programming you must check what kind of fuel gauge sensor you have on the car.
- Masa -
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 11 Touko 2016, 22:21
Amm.. ok. Sorry im a complete noob in this) . How about we meet and you check it ? And programme. :ruoska:
Re: display safe
Viesti Kirjoittaja kadett90 » 18 Touko 2016, 15:01
What about upcoming weekend?
- Masa -
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 18 Kesä 2016, 11:05
Hi. I can do it . Evenings today or tomorrow Sunday after 17 o'clock. Let me know if its good.
AdamOPC
Re: display safe
Viesti Kirjoittaja AdamOPC » 13 Heinä 2016, 20:53
Thank you very much man!!!! Everything now works perfectly . Im happy :). KIITOS
Re: display safe
Viesti Kirjoittaja kadett90 » 13 Heinä 2016, 21:37
Great to hear that everything works. :thumbsup:
- Masa -
Dinkke
Re: display safe
Viesti Kirjoittaja Dinkke » 21 Heinä 2016, 10:14
Moi!
Searchilla löytyi tämä topicci ja lähes sama murhekkin ja ajattelin laittaa kysymystä jatkoksi:)
Eli siskoni osti -04 H astran jossa alkuperäinen soitin kiinni, tosin soitin vaihdettu käsittääkseni takuuseen joskus. Näyttöön syttyy hetki auton starttaamisen jälkeen teksti "display safe".
Musiikki kuuluu mutta mitään muuta ei oikeastaan pysty tekemään, onko tälle ongelmalle olemassa mitään ratkaisua arvon opel gurut :worship:
