Mulla alkoi jo vuosi sitten vaihtelevasti temppuilemaan tuulettimen moottori.
Vaihdoin esivastuksen ja moottorin ja sama juttu. Myös virtalukonpohja tuli vaihdetuksi. Nyt näyttäisi että ongelma on BCM-keskeinen. Olen asian suhteen melko amatööri, mutta ymmärsin, ettei tuon vaihtaminen onnistu plug&play mallilla. Mitäs tehdään? Millanen budjetti tähän kannattaa varata?
Alla koodeja:
Car Scanner ELM OBD2
Version: 1.121.0/1.121.0/iOS
DTC report
Connection profile: Opel OBD-II / EOBD + CAN 11 bit (2004 - present)Date: 10/4/2025 10:59:32 AM
VIN: W0LPF6ED5A8088170
OBD-II
No DTC found.
Engine control unit
No DTC found.
BCMBCM
DTCs: 8
U0151 [0xC151]
Data bus, supplementary restraint system (SRS) control module - no communication
General Electrical Failures [0x00]
Status: DTC supported by calibration, Current DTC, Test failed since DTC cleared, History DTC, Test not passed since current power up
B151A [0x951A]
Algorithm Based Failures: incorrect reaction after event [0x58]
Status: DTC supported by calibration, Test failed since DTC cleared, History DTC
B3210 [0xB210]
Right Passenger window motor circuit malfunction; Right Front Window Motor Circuit Internal Malfunction; Right Front Window Motor Circuit Calibration Not Programmed; Right Front Window Motor Circuit Calibration Not Learned
ECU Programming Failures: calibration not learned [0x4B]
B3806 [0xB806]
Headlamps highbeam and flash to pass select circuit malfunction
B3882 [0xB882]
Right Tail Lamp Circuit Short to Ground; Right Tail Lamp Circuit Open
General Electrical Failures: open circuit [0x04]
U0164 [0xC164]
Data bus, AC control module - no communication
Status: DTC supported by calibration, Test failed since DTC cleared, History DTC, Test not passed since current power up
U151A [0xD51A]
(K9 Body Control Module) LIN Bus 1 Lost Communication With Device 10 (B117 Windshield Outside Moisture Sensor)
Status: DTC supported by calibration, Current DTC, Test failed since DTC cleared, History DTC, Test not passed since current power up, Current DTC since power up
B3205 [0xB205]
Left Driver window motor circuit malfunction; Driver Window Motor Circuit Internal Malfunction; Driver Window Motor Circuit Calibration Not Programmed; Driver Window Motor Circuit Calibration Not Learned
EPS / TDM
No DTC found.
ABS/EBCM/ESCABS/EBCM/ESC
DTCs: 1
C0710 [0x4710]
Steering Position Signal Malfunction; Steering Position Signal Calibration Not Programmed; Steering Position Signal Not Plausible; Steering Position Signal Invalid Data
Bus Signal/Message Failures: Erratic [0x7F]
Status: DTC supported by calibration, History DTC, Test not passed since current power up
Parking brake
No DTC found.
Opel Astra J BCM
jonipeepee
Re: Opel Astra J BCM
Ja nyt itseasiassa pitkän tauon jälkeen alkoi pyöriä se moottori kun sammutin auton
