Re: Insignia 1.6 turbo Cosmo tehot
Lähetetty: 23 Tammi 2015, 19:50
Tuommoinen tiiä sitte onko basic vai mikä
Opel, Saab, GM, Vauxhall, Holden vikakoodinlukija ja paljon muuta. Versio 1.45
Agila, Antara, Astra, Calibra, Campo, Captiva, Captiva MAXX, Combo, Corsa, Frontera, Insignia, Meriva, Monterey, Movano, Omega, Sintra, Speedster/VX220, Tigra, Vectra, Vectra/Signum, Vivaro, Zafira, SAAB 9-3, SAAB 9-5...
huoltovälin nollaus
airbag nollaus
vikakoodien lukeminen ja poistaminen
moottorin diagnostiikka-arvojen seuraaminen reaaliajassa
suoritusarvojen mittaaminen
laitteiden koodaaminen
jne
Pakkauksessa mukana:
1x USB kaapeli (adapteri) v 1.45
1x Ohjelmalevy (v. 2010.08)
Agila 2000-2010
Antara 2007-2010
Astra-F 1992-2002
Astra-G 1998-2010
Astra-H 2004-2010
Astra-J 2010
Calibra 1990-1999
Campo 2001-2003
Captiva 2006-2010
Captiva MAXX 2010
Combo 1994-2010
Corsa-B 1994-2003
Corsa-C 2000-2010
Corsa-D 2006-2010
Frontera 1992-1999
Frontera-B 1999-2003
Insignia 2009-2010
Meriva 2003-2010
Monterey 1997-1999
Movano 1999-2010
Omega 1990-2003
Sintra 1997-1999
Speedster/VX220 2001-2007
Tigra 1995-2010
Vectra-A 1990-1995
Vectra-B 1996-2002
Vectra-C/Signum 2002-2010
Vivaro 2001-2010
Zafira 1999-2005
Zafira-B 2005-2010
GM:n SAAB 9-3
GM:n SAAB 9-5
OP-COM Functions:
1. It covers almost all Opel cars, even new cars with CAN-BUS based diagnostic, such as Vectra-C, Astra-H, Zafira-B.
2. The program lets you to read out and clear fault codes, shows you live data, lets you to perform output test.
3. The program supports many control units, like Engine, Automatic Transmission, ABS, Airbag, Engine Cooling module, Instrument Cluster, Electronic Climate Control, Body Control Unit, just to name a few examples.
4. Since Opel uses many pin in the OBD connector, the diagnostic interface works as a multiplexer, and selects the appropriate pin for communication.
PIN3, PIN7, PIN8, PIN12 = Serial Link (ISO9141, KW81, KW82, KWP2000)
5. Fault codes will be shown with all available information.
OP-COM features:
1) Full status information (Present, Not present, Intermittent)
2) You can print out, save, or copy the fault codes to any other application. From the fault codes window, you can go directly to the measuring blocks window.
3) The program shows you measuring block information on many control module, you can choose anything from the list on your own.
4) The program is capable of showing 8 measuring block parameter simultaneously. The sample rate is depends mostly on the communication protocol. For example, older system, like Omega-B X 25 DT Engine (ISO-9141-2) can be very slow, during communication, while newer Multec, or Bosch units are faster (using KWP-2000), and the newest CAN based control units are very fast!
You can also run output tests on many controllers.
PIN6-PIN14
PIN3-PIN11
PIN1
HSCAN - Dual-wire, High Speed CAN-BUS, 500 kbps
MSCAN - Dual-wire, Medium Speed CAN-BUS, 95 kbps
SWCAN - Single-wire, Low Speed CAN-BUS, 33.3 kbps
Package List:
1. OP-COM Interface (Hardware Version: 1.45)
2. USB Cable
3. Software and Drivers CD (Software Version: 201008)
huoltovälin nollaus
airbag nollaus
jne
Agila 2000-2010
Antara 2007-2010
Astra-F 1992-2002
Astra-G 1998-2010
Astra-H 2004-2010
Astra-J 2010
Calibra 1990-1999
Campo 2001-2003
Captiva 2006-2010
Captiva MAXX 2010
Combo 1994-2010
Corsa-B 1994-2003
Corsa-C 2000-2010
Corsa-D 2006-2010
Frontera 1992-1999
Insignia 2009-2010
Meriva 2003-2010
Monterey 1997-1999
Movano 1999-2010
Omega 1990-2003
Sintra 1997-1999
Tigra 1995-2010
Vectra-A 1990-1995
Vectra-B 1996-2002
Vivaro 2001-2010
Zafira 1999-2005
Zafira-B 2005-2010
GM:n SAAB 9-3
GM:n SAAB 9-5
OP-COM Functions:
OP-COM features:
PIN6-PIN14
PIN3-PIN11
PIN1
Package List:
2. USB Cable
