Jarppa30 kirjoitti:Saakos tuohon vanhempaan kiinan Opcomiin mitenkään ajettua uutta firmvaree eli mun kalikka versioo 090820B ja en saa millään Opcomin versiolla sitä toimimaan.Herjaa vaan aina että Interfaceen ei saa yhteyttä vai onko vaan susi kappale mikä mulla on.Täytyy varmaan tilata se uudempi versio jos ei saa päivitettyä.USB ajurit sain asennettua oikein näkyy USB laitteissa mutta ei vaan toimi,käyttiksenä XP.Tuo AMP:n Opcom versio yrittää päivittää firmiksen mutta kaatuu Interface virheeseen asennus eli taitaa olla ser-romua tuo paska.
RECOMMENDED SOFTWARE - UPDATING YOUR SOFTWARE AND FIRMWARE
IMPORTANT INFORMATION.
DO NOT DOWNLOAD SOFTWARE FROM OTHER SITES, especially Ilexa and Auto3M.
Ilexa and Auto3M software has been known to destroy / erase the PIC chip inside the interface. You are then left with a useless interface.
It is recommended that you only use software from the sister site.
This has all been tried and tested by Big Rob (drdre20013). And so all the software is perfectly safe to use with your "China Clone" interface.
If you have lost your Interface driver disc, then download a piece of software starting with the prefix 09**** (This signifies 2009 software). This software also contains the interface USB driver.
You should download the latest software - Currently this is 100219a
This software is a lot more stable than earlier versions, and it is also able to offer more functions.
This software does not need any activation codes etc.
All you do is: -
Down load the software
UnZip / Unpack the software
Then you can simply run the software by clicking on the OPCOM icon.
Finally, some version of software have caused Virus warnings to be displayed..
The software does NOT contain any viruses, but does contain some files that look similar to a virus according to many anti-virus software packages.. such as Kasperski etc.
There is nothing to worry about, when installing software from the link above.
Eli poistin aikasemman softan ja ajurit tietokoneesta ja sitten tein tuon ohjeen mukaan.
Kiitos vos,mutta ei se pelaa tuollakaan paketilla aina vaan pukkaa interface erroria.Mitäs toi tekee jos antaa kokeilla tota Internet Updatea? Kyseinen paketti ei kyllä yritä edes sitä firmwaree päivittää......... tai jos siinä kävikin näin kuten tuolla foorumilla sanotaan:DO NOT DOWNLOAD SOFTWARE FROM OTHER SITES, especially Ilexa and Auto3M.
Ilexa and Auto3M software has been known to destroy / erase the PIC chip inside the interface. You are then left with a useless interface.No sehän se oli kun löysin tuon työkalun millä kattoo palikan sisään tarkemmin herjaa että PIC is empty kun yrittää firmistä sisään heittää.Täytyneen tilata toi e-villen versio sitten.
Jarppa30 kirjoitti:Kiitos vos,mutta ei se pelaa tuollakaan paketilla aina vaan pukkaa interface erroria.Mitäs toi tekee jos antaa kokeilla tota Internet Updatea? Kyseinen paketti ei kyllä yritä edes sitä firmwaree päivittää......... tai jos siinä kävikin näin kuten tuolla foorumilla sanotaan:DO NOT DOWNLOAD SOFTWARE FROM OTHER SITES, especially Ilexa and Auto3M.
Kun latasit ohjelman tietokoneelle ja sitten kytkit usb-mokkulan kiinni, niin tuossa vaiheessa tietokoneen olisi pitänyt asentaa/asennuttaa ajurit.
Vaikuttaa että et ole asentanut ajureita tuolle usb-mokkulalle...
Ne ajurit pitää asentaa sieltä op-com ohjelman kansiosta.
Tein niin kuin kerroit poistin vanhan ohjelman ja ajurit,käynnistin koneen uudelleen,tökkäsin palikan kiinni ja siinä vaiheessa kone pyyteli ajureita ja asenti ne sieltä kansiosta johon olin ne purkanut,kaikki meni kuten pitikin mutta Interface test ei mennyt edelleenkään läpi.Samalta sivulta löysin tämän ohjelma OPComFUT29b jolla voi päivittää firmwaren uudempaan kun OpCom ei sitä tehnyt.Kyseinen ohjelma herjasi ja kertoi PIC chipin olevan empty eli ei voi päivittää palikkaa. Kun rupesin illalla asiaa mietiskelemään aikoinaan kun palikka tuli se toimi pari päivää ja jossain vaiheessa ohjelma ilmoitti halusta päivittää itsensä ja minä typerys sallin sen ja palikka lakkasi toimimasta sen jälkeen eli päivitys tuli sit varmaan jostain väärästä paikasta ja ohjelma tyhjensi PIC chipin kuten tuolla linkki sivullasikin mainittiin asiasta.
E-Villestä uusi tilattu jotenka vanha myydään/annetaan jos joku haluu kokeilla saako sen toimimaan. Kiitoksen vos:sille neuvoista!
Toivotavasti en ryssi uutta palikkaakin.
Viikon päästä voi olla toimiva palikka Lahti/Hollola alueella,jos joku tarvii apuja!
No niin,uusi palikka tuli ja toimii.Testasin omassa B-vecussa ja emännän veljen G-astrassa joka onkin kiukutellut välillä ja tällästä listaa sieltä irtos jos joku osais selventää tämän.
P0105 Manifold Absolute Pressure (MAP) Sernsor Voltage High.
Map anturihan se herjaa mut mitä toi Voltage High meinaa? ilmeisesti uutta anturia kaipailee.
Onks jossain saatavilla kattavaa listaa noista vikakoodeista?
Kiitos jo etukäteen!
Lahti/Hollola akselilla toimiva palikka jos joku tarvii luku apuja.
Opcomilla pystyy nostamaan tyhjäkäyntiä ainakin z22se:ssä, se on siellä testit osiossa. Pysyväksihän sitä tyhjäkäynnin nostoa ei saa, mutta pystyy kuitenkin nostamaan, yläraja tais olla 1500rpm ja alaraja joku 400rpm
Astra H GTC -05 Z20LER
Vectra B2 Sport -01 Z22SE Ex.
noniin tuli e-villestä tilattuu tollanen vekotin jossa chinaclone ohjelma.....lampunpesurit poistettu käytöstä, turvavyön varoitin kytketty,chek control kytketty ja ajovalomuistia muunneltu....mahtava laite....mittarilukemankin tuolla vois muuttaa....ja kyseessä c vectra facelift....rengaspaine varoittimenkin sieltä saa kaivettua esiin...
Kokovartalo Vectra C2, Astra F 1600, Insignia A20DTH SPORT TOURER
On varmaan joskus ollut jotain keskustelua, en vaan löytänyt. Käykö tämmönen Bluetooth lukija Opeleitten OBD-2 väylään:http://www.ebay.com/itm/Auto-Car-V1-4-E ... 5ae0c45e90. Tuossa ei mainita kun VAG konsernin vehkeistä vaan. Vai sitte tämä:http://www.dealextreme.com/p/obdii-blue ... -12v-42825.Näyttävät kyllä aika samanlaisilta. Olis vaan aika messevää, kun näkisi auton dataa android luurilla. Tarvii tosin Torgue ohjelmisto luuriin asentaa.
Vectra C2 2.8T Sport Caravan
Omega B2 2.2 Selection
EX Omega B2 2.2 Classic Caravan
EX Vectra B1 1.8 CD Caravan
EX Omega A 2.0 Irmscher
EX Kadett E 1.3GLS
erehdys kirjoitti:On varmaan joskus ollut jotain keskustelua, en vaan löytänyt. Käykö tämmönen Bluetooth lukija Opeleitten OBD-2 väylään:http://www.ebay.com/itm/Auto-Car-V1-4-E ... 5ae0c45e90. Tuossa ei mainita kun VAG konsernin vehkeistä vaan. Vai sitte tämä:http://www.dealextreme.com/p/obdii-blue ... -12v-42825.Näyttävät kyllä aika samanlaisilta. Olis vaan aika messevää, kun näkisi auton dataa android luurilla. Tarvii tosin Torgue ohjelmisto luuriin asentaa.
Kyllähän tuo ELM327 toimii, mutta näyttää vain moottorin ECUn. Itse olen käyttänyt juurikin Torqueta Androidilla ja tuota ELMiä. Nyt tilauksessa
tosin OpCom että näkee kaikki ECUt
Opel Grandland X 1.2T AT Innovation -18
Ford Mustang 5.0 GT -94
-ex Opel Mokka 1.4T AT Cosmo -14
-ex Opel Vectra 3.2 V6 Elegance Caravan -05
-ex Volvo V50 2.0D -04
-ex Opel Vectra 2.2 Ecotec -03
Mulla toi kiinanpommi taisi hajota. Kertaalleen toimi ok, sain viat nollattua ja vakkarin toimimaan. Nyt sitten lopetti toiminnan. Ei kyllä tajua mistä on kyse kun interface-testi ilmottaa kaiken olevan ok. TX-valo vilkkuu, vaan RX ei sano mitään, OPCOM ilmoittaa vaan ettei ecu vastaa. Kokeilin vielä päivittää firmiksen ohjeiden mukaan ja vielä toista läppäriäkin, ei mitään. Kele.
